DIAdem
How to call .chm Help File
How to call .CHM help file on click of button through the dialog? I tried using the command WinHelpCall() but unable to find the required result. Also could anyone please suggest how to I get a link/jump to the subtopics on click of help button under that module Example Under Navigator device if the help button is clicked the help file has to display Navigator Page.
Can anyone provede me a quick suggestion.
Thanks in Advance
(3,833 Views)
DIAdem doesn't have a method to open .chm files because these files are Microsoft help files, rather than DIAdem specific help files. However, there is a KnowledgeBase on Microsoft's web page that may be of help. You can find this document at http://support.microsoft.com/?kbid=209843. I found this by doing a web search for "Programmatically open .chm". I hope this helps you.
Shannon R.
(3,833 Views)
I just found out about the WinHelpCall in DIAdem. Sorry about my previous incorrect post. Check out this post, which has a much more complete (and correct) answer. WINHelpCall is not working properly why
(3,833 Views)
