DIAdem
How to change the channels of an 2D-Axis report using script
D2ChnX(i),D2CChnX.... doesn't really work
Please a short example
Diadem 9.1 on WIN2000
(4,186 Views)
Hi PeterBR,
I hope the following script base functions may help you:
'-- VBS - Autosequenz - Datei
'-- Neu erstellt am 22/01/2002 11:26:43
'-- Ersteller:
'-- Kommentar:
Option Explicit
call SetNewParameter
Sub SetNewParameter
Dim iObjNo,sObjType
call NewParamFor_Main_Frame
For iObjNo = 1 To ObjectNoMax
if ( 0 < Len(PicObj(iObjNo)) ) Then
sObjType = Lcase(PicObjType(iObjNo))
Select Case sObjType
Case "freeframe"
Call NewParamFor_Frame_Obj(PicObj(iObjNo))
Case "textline"
Call NewParamFor_Text_Obj(PicObj(iObjNo))
Case "xy"
Call NewParamFor_XY_Obj(PicObj(iObjNo))
Case "xyz"
Call NewParamFor_XYZ_Obj(PicObj(iObjNo))
Case "xytab"
Call NewParamFor_XYTab_Obj(PicObj(iObjNo))
Case "xyztab"
Call NewParamFor_XYZTab_Obj(PicObj(iObjNo))
Case "polar"
Call NewParamFor_Polar_Obj(PicObj(iObjNo))
Case Else
End Select
End If
End Sub
' Set for main frame to new colors
sub NewParamFor_Main_Frame
' do something
end sub
' Set for frame objects to new colors
Sub NewParamFor_Frame_Obj(sObjectName)
Call GRAPHObjOpen(sObjectName)
' do something
Call GRAPHObjClose(sObjectName)
End Sub
' Set for text objects to new colors
sub NewParamFor_Text_Obj(sObjectName)
' do something
end sub
' Set for 2-D Axis system to new colors
Sub NewParamFor_XY_Obj(sObjectName)
call GraphObjOpen(sObjectName)
For iCurveNo = 1 To CurveNoMax
if D2CURVEOBJ(iCurveNo) <> "" then
call GraphObjOpen(D2CurveObj(iCurveNo))
' do something
call GraphObjClose(D2CurveObj(iCurveNo))
end if
call GraphObjClose(sObjectName)
End Sub
' Set for 3-D Axis system to new colors
Sub NewParamFor_XYZ_Obj(sObjectName)
if D3CURVEOBJ(iCurveNo) <> "" then
call GraphObjOpen(D3CurveObj(iCurveNo))
' do something
Call GRAPHObjClose(D3CurveObj(iCurveNo))
end if
next
End Sub
' Set for 2-D table system to new colors
Sub NewParamFor_XYTab_Obj(sObjectName)
' do something
End Sub
' Set for 3-D table system to new colors
Sub NewParamFor_XYZTab_Obj(sObjectName)
' do something
End Sub
' Set for Polar Axis system to new colors
Sub NewParamFor_Polar_Obj(sObjectName)
If D2PolarCURVEOBJ(iCurveNo) <> "" Then
Call GRAPHObjOpen(D2PolarCURVEOBJ(iCurveNo))
' do something
Call GRAPHObjClose(D2PolarCURVEOBJ(iCurveNo))
end if
next
End Sub
Greetings
Walter Rick
(4,186 Views)
Hi Rick,
thanks for your quick answer!
But if i try to change the channel of a curve, it has no effect!
....in Sub NewParamFor_XY_Obj...
D2CChnX = "6" 'no effect!!!
D2CChnY = "8" 'no effect!!!
D2CurveColor = "yellow" 'works!!!
Is D2CChnX read only?
Greetings
Peter
(4,186 Views)
Hello Peter
This depends if you are working name oriented (default) or number oriented. This is set in Settings>>Layout parameters.
So if you use channel names it will work in the name oriented mode.
D2CCHNX = "[1]/MYch6"
D2CCHNY = "[1]/MYch8"
Or try this. This will work for all modes.
If CBool(PICDEFBYIDENT) Then
D2CCHNXNAME = CN(6)
D2CCHNYNAME = CN(8)
Else
D2CCHNX = 6
D2CCHNY = 8
End If
Hope this helps!
(4,186 Views)
Hello Rick,
now it works!
thanx a lot!!
Maybe you can add this last hint in your help under
Index --> "Objekte, DIAdem-REPORT"
D2CChnXName is not linked on this page!
Have a nice Week
Peter
(4,186 Views)
