DIAdem
How to check if Sud Dlg1 already exists?
Hi, I have some code in a script that creates a Sud Dialog (SudDlgCreate("Dlg1",...). However, when I want to run the script again it complains that:
"A dialog box called "DLG1" already exist."
Is there any way to check if the Dlg1 already exists? Like this:
If Dlg1 = 0 Then
Set MyDlg = SudDlgCreate("Dlg1","C:\Temp\QuickTools.sud")
Thanks in advance
/Mike
(1,363 Views)
Accepted by topic author Mike_77
Worth trying
Dim i
For i = 1 to SudNonModalDlgCount
  if SudNonModalDlgLst(i).DialogCode = "Dlg1" Then
    Call MsgBoxDisp(SudNonModalDlgLst(i).DialogCode & " Exists")
  end if
(1,342 Views)
Thank you, it works perfect!
(1,324 Views)
