DIAdem
How to configure to NI Multifunction 6251 DAQ card to DIAdem DAC Version?
            I am Thiyagi. I am trying to configure to Multi function 6251 Daq card to DIAdem DAC software.
           Please send me the step by Step configuration Procedure.
Thiyagi.S
Thiyagarajan.S
WABCO Vehicle Control System
(4,394 Views)
Hello Thiyagu,
The following steps describe how to configure a measurement with NI hardware in DIAdem:
  • Configure your hardware in MAX. It is necessary to define “Global Virtual Channels” in MAX for each signal you would like to measure with DIAdem.
  • Open DIAdem DAC and choose “NI DAQ driver” (icon DAQ) in the toolbar “Driver inputs”.
  • Open the “NI DAQ” block and select the signals to measure
  • Complete you DAC scheme with other function blocks of DIAdem DAC and start the measurement.
Greetings
Walter
(4,379 Views)
Hi Thiyagu,
Maybe it helps if you take a look in the user manual "Data Acquisition and Visualization". The second chapter "Installing Measurement Hardware and Communicating via Interfaces" should answer your questions. You'll find this manual either printed in your DIAdem box or as a PDF from the menu Help>>Introduction Screen in the Manuals section.
Ralf
(4,376 Views)
Accepted by topic author Thiyagu
     As per your information, I tried in my software.
     It is working fine.
    Thanks for your great support.
Thiyagarajan.S
(4,371 Views)
