DIAdem
How to connect to Netezza database
I am trying to use DIAdem instead of Aginity to connect to Netezza database.  I have tried the following code, but cannot get a successful connection. Any help is appreciated.
ConnectionStr = "Driver={NetezzaSQL};server=______;UserName=______;Password=______;Database=______;LoginTimeout=120"
Set ADO = CreateObject("ADODB.Connection")     'I have tired a few options here including "NZSQL.Connection"
ADO.Open ConnectionStr
Message 1 of 10
(9,285 Views)
The following code can be used to use the MS ADO dialog to determine the connection string.
Option Explicit
Call ADOConStrGet()
dim conStr : constr = ADOConString
if "" <> conStr then
  dim conFile : conFile = TmpDrv & "constr.txt"
  FileWriteLn conFile, 0, conStr
  MsgBox "Result in: '" &  conFile & "'" & VBCRLF & conStr
end if
The dialog contains a test button where you can play till it works.
Hope this helps.
Message 2 of 10
(9,283 Views)
This was helpful, but it does not seem to see the Netezza connection.
Screen shot of issue
Message 3 of 10
(9,281 Views)
I have no idea about Netezza but if it has an odsbc driver and is installed on your machine as an system dsn
DSN=NZSQL;Uid=myUsername;Pwd=;
should be sufficient. Maybe you need to add the driver.
Driver=NetzzaSQL;DSN=NZSQL;Uid=myUsername;Pwd=;
The name of the driver should be pickable on the first Tab Provider.
Maybe it will show up afterards. Aktually you are only seeing those of the ODBC provider.
Please visit the Provider Tab and check if you can switch the driver to Netezza.
Message 4 of 10
(9,273 Views)
This is still an open question.  I can connect using Tableau Desktop software, but cannot get DIAdem to connect to IBM PDA (Netezza)
Message 5 of 10
(9,134 Views)
How does the Provider Tab look like?
Message 6 of 10
(9,130 Views)
provider tab
Message 7 of 10
(9,121 Views)
I have no idea how this works out. There seems to be no special driver.
"Provider=IBMDADB2;DSN=NZSQL;User Id=;Password=;"
is someting that can be found on the IBM pages for DB2.
All of this is just guessing. The connection string is indivual to the target database.
The dialog showing up with
ADOConStrGet()
is a native MS ADO dialog. So it should be possible to configure the connection there and validate it by using the test button, but I have no clou what to fill in for your database.
Smiley Sad
Andreas
Message 8 of 10
(9,107 Views)
Under my ODBC Data Source Administrator --> System DSN tab.  Name = "NZSQL", Driver = "Netezza SQL" shows separately from the IBM DB2 ODBC Drivers.  I believe that Netezza is different from DB2.  I can connect with Tableau Desktop and R Studio.  It looks like DIAdem is not recognizing the driver....
Message 9 of 10
(9,096 Views)
What error do you get if you use
without giving the driver at all?
P.S.: There is no implementation at this point. VBS just uses Microsoft ADO (Com Component) to connect to the databases. Like you see in the dialog the Driver is nt registered in ADO. Could you ask the person setting up the database for the connection string.
Message 10 of 10
(9,089 Views)
