DIAdem
How to convert MATLAB program to Diadem script
Brad:
I'm at a loss as to how to convert this function from Matlab to Diadem...any suggestions?  In Matlab it would convert the number to a string
Akj=num2str(j) ',' num2str(j)];%write the subscripts as strings with a comma to serparate rows and columns
Message 11 of 14
(3,119 Views)
Hi jgabe,
Here's a start for you.  You loop For i = 1 to imax, the concatenation operator is "&", the string constant character is ", every if needs a then, the comment character is ' etc.:
'fill the matrices of simultaneous equations
n=0
for i = 1 to (nfil-1)
    for j = (i+1) to nfil
        Aij = "[" & i & "," & j & "]" 'write the subscripts as strings with a comma to serparate rows and columns
        n = n + 1
        nn = 0
        for ii = 1 to (nfil-2)
             for jj = (ii+1) to nfil
                 for kk = (jj+1) to nfil
                     nn = nn + 1
                     Bii = CStr(ii) 'write the subscripts as strings
                     Bjj = CStr(jj)
                     Bkk = CStr(kk)
                     if strcomp(Aij, "[" & Bii & "," & Bjj & "]") then 'compare subscripts as strings with row and column separated by a comma
                         MatUR(n,nn) = MatUR(n,nn) + 1
                         MatLL(nn,n) = 1
                     elseif strcomp(Aij, "[" & Bjj & "," & Bii & "]") then
                         MatLL(nn,n) = -1
                     elseif strcomp(Aij, "[" & Bjj & "," & Bkk & "]") then
                         MatLL(nn,n) = 1
                      elseif strcomp(Aij, "[" & Bkk & "," & Bjj & "]") then
                         MatUR(n,nn) = MatUR(n,nn) - 1
                         MatLL(nn,n) = -1
                     elseif strcomp(Aij, "[" & Bkk & "," & Bii & "]") then
                         MatLL(nn,n) = 1
                     elseif strcomp(Aij, "[" & Bii & "," & Bkk & "]") then
                         MatLL(nn,n) = -1
                     end if
                 next
             next
        next
    next
next
Brad Turpin
DIAdem Product Support Engineer
Message 12 of 14
(3,093 Views)
thanks Brad!  Your awesome!
Message 13 of 14
(3,091 Views)
Hi jgabe,
I expect more questions, this is really just the first step, but hopefully it'll get you jumpstarted some.
Brad Turpin
Message 14 of 14
(3,079 Views)
