DIAdem
How to customize DIAdem tool?
Problem
Is there away for me to add custom button or feature into DIAdem using LabWindow program?
Requiremnts
Custom button will run my CVI application do following:
  • import binary file from other format into CSV format
  • automatic load this file into DIAdem
  • bring up the graph display
  • automatic save CSV into TDM/TDMS format
  • run report.
(4,951 Views)
Hello NiCoder,
You can definitely add an icon or menu entry to execute a script or run an executable.For the steps you listed DIAdem has all the function you need.
Is there a specific reason that you want to use the LabWindows program ? Using the DIAdem function should be more efficient.
As long as there is a description of the binary file it should be possible to create a DataPlugin which then would enable DIAdem to read the file natively. That would skip some of the conversion, thus making the process more efficient.
Andreas
(4,938 Views)
We want to use the c language because we did not want the user reserve the visual basic code.  Would you send or point me the instructions of how to create the plugins?
(4,895 Views)
Accepted by topic author NiCoder
Please take a look at www.ni.com/dataplugins. There is a link "DataPlugins programmer's reference guide" with teh required documentation and manuals. The language used is VBScript. VBScript is used as a kind of glue code to configure the functions doing the real work.
(4,892 Views)
