DIAdem
How to detemine the row and column count of a table
How Can I detemine the row and column count of a table which is already existing in a Report?
Regards
(4,046 Views)
Hello Sarry,
Please try d2TabRow and d2TabCol
Greetings
Walter
(4,044 Views)
Hi Sarry,
If you meant the total number of rows and columns in a table, here's your best approach:
TableName = "2D-TableName"
Set Sheet = Report.Sheets(1)
IF Sheet.Objects.Exists(TableName) THEN
  Set Table = Sheet.Objects(TableName)
  Cols = Table.Columns.Count
  Set Settings = Table.Settings.IndexSettings
  RowStart = Settings.IndexBegin
  RowStop  = Settings.IndexEnd
  Rows = RowStop - RowStart + 1
  MsgBox "Rows = " & Rows & vbCRLF & "Cols = " & Cols
ELSE
  MsgBox "Could not find Table """ & TableName & """"
END IF
Brad Turpin
DIAdem Product Support Engineer
(4,030 Views)
