DIAdem
How to determine variable array length?
I am writing a piece of code that is manipulating the Root Description.  Here's what I have.   :
Dim DescriptionArray
DescriptionArray = Split(RootPropGet("description"), " ", -1, 1)
After this command, I now want to figure how long (how many items) DescriptionArray has.  What is the command for that?
Brian
(6,214 Views)
Accepted by topic author Brian E
Hello Brian!
The command is UBound. It gives you the highest index of the array. Because VBS starts with index 0 you have to add 1 to get the count.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(6,203 Views)
Thanks.  This is what I was looking for.
(6,191 Views)
