DIAdem
How to drag & drop multiple channels into View without them plotting against the first selected channel
I frequently find the need to select multiple channels data in the Portal (ctrl + click to select or shift click) then plot them into View. I realize that this will plot n channels vs the first selected channel which is not what I want. Current workaround is I select only 1 channel then drag it into View, then repeat for other channels. Could you please suggest a solution ?
By the way, there is no "X axis" channels, all channels should sit on "Y axis".
Thanks !
(3,031 Views)
I just found my answers, I think... It is not possible Smiley Frustrated
https://forums.ni.com/t5/DIAdem/Use-index-for-xaxis-when-dragging-multiple-channels/td-p/3572106
But now I have another question, let say I have 3 data channels, and 1 time channel. If I click on time channel and hold CTRL and click on 3 data channels separately, then drag them into VIEW, it works just as expected. But if I click on time channel, hold shift (or ctrl shift) and select on 3 data channels at once, then drag them into VIEW, it didn't work.
(2,998 Views)
