DIAdem
- How to draw a graph in Diadem after importing the excel file?
- I also want to know if you can modify the scale of the graph?
My operating system is Windows ME, Diadem evaluation package V 8.1 .
(3,577 Views)
If you open the device GRAPH you can select different graphical object types (with the toolbar closed to the device bar on the left). For example you can select a 2D axis system. With double click you open a dialog to configure the channel pairs you would like to be displayed (button ?New entry??). There are several parameters to configure the axis system ? most are selectable via buttons and dialogs (axis definition-> scaling to scale the axis individually). By the way if you double click on the Y-axis directly you will get the dialog for setting the Y-scaling.
I hope this will help you.
Greetings
Walter Rick
(3,577 Views)
