DIAdem
How to export a chart from REPORT to PowerPoint without a border
I am exporting a series of 3D plots from DIAdem REPORT to PowerPoint (I am using DIAdem 2010) and can't find a way to export a chart with no border (i.e. a chart that floats on the page, with no defined border around the drawing object).
Is this a setting somewhere in DIAdem?
Thanks!
(4,004 Views)
David,
I might be stating the obvious here, but in REPORT when you go to the "Settings" menu, select "Layout Setup > Layout Parameters"
There, disable the "Frame".
That should do the trick for you.
Let me know if that helped,
     Otmar
Otmar D. Foehner
(3,999 Views)
Otmar,
Yes, it does. Sorry  - coming from Excel I had assumed it must be a property of the chart itself, not of the whole drawing area within REPORT.
Thanks for the fix! As you can tell, I am still learning DIAdem.... 🙂
(3,994 Views)
