DIAdem
How to export results from DIAdem script to Excel sheet?
Hello, I have measured Vibration and Acoustic Data for about 180 seconds. I wanted to divide the file into 25 time slices. I displayed in View (DIAdem) and started manually to get the x-axis for each part. 9626 201600 201600 385229 385229 563661 563661 749850 749850 948813 948813 1158042 1158042 1412557 1412557 1587456 1587456 1747968 1747968 1921306 1921306 2120294 2120294 2319232 2319232 2506035 2506035 2692173 2692173 2909056 2909056 3090022 3090022 3241805 3241805 3456128 3456128 3657882 3657882 3820877 3820877 3978803 3978803 4168038 4168038 4338816 4338816 4509594 4509594 4698266 4698266 The above is my the start and end of each time slice. Then I created a Script in DIAdem. To calculate all possible descriptive Statistics analysis. That is my script (see attachment) Now my Question is , How can I export the statistics to Excel sheet or any 2D table for the 25 Time slices? Many thanks in advance for your understanding and cooperation. Best regards Ihab
(6,538 Views)
Accepted by topic author Ihab
Hi lhab,
Have you checked out this Knowledgebase Article: How can I programmatically Import My Data from Excel to Diadem or Export it From Diadem to Excel?
Hassan Atassi
Senior Group Manager, Digital Support
(6,527 Views)
Hello!
If you want to insert them in an existing workbook you can use COM similar to this example.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(6,521 Views)
