DIAdem
How to generate a diadem web service client from a WSDL file?
(4,984 Views)
Please find below a little example. It's very basic and the details are specific for the webservice. In general all you need are the two lines marked in blue. The example doesn't have any error checking. I recommend to add at least some basic functionality to check whether the service is available.
Andreas
' Example showing how to use a webservice from VBS
Dim oSoapClient,objXML,sgResponse,oRoot,oNodes,oChildNode,I,sgLog
Set oSoapClient = CreateObject("MSSOAP.SoapClient")
Set oXMLDOM     = CreateObject("Microsoft.XMLDOM")
' create SOAP wrapper for webservice
Call oSoapClient.mssoapinit("http://www.webservicex.com/stockquote.asmx?WSDL")
' Get quote for NATI stock. Data is formatted as XML/DOM strcuture
sgResponse = oSoapClient.GetQuote("NATI")
' Parse XML
oXMLDOM.LoadXML(sgResponse)
' List properties
Set oRoot = oXMLDOM.documentElement
' Parse property nodes
Set oNodes = oRoot.childNodes.Item(0)
sgLog = ""
For Each oChildNode In oNodes.childNodes
  sgLog = sgLog &oChildNode.baseName&"  :  "&oChildnode.text & vbCR
Call MsgBox(sgLog,,"Data for NATI")
(4,976 Views)
Is this functionality still available in 2019? Executing this code with DIAdem 2019 gives the error message: "ActiveX component can't create object: MSSOAP.SoapClient". Maybe there is another way to send SOAP-requests with the current version? Kind regards.
(2,586 Views)
