DIAdem
How to get channel Index
Hello DIAdem Users,
I want to look for a particular string in the Channel's name and once I find that string in a channel'sname then I want to have its index. How can I achieve that?
Regards
(5,864 Views)
Accepted by topic author Sarry
Option Explicit
dim groupObj : for each groupObj in data.root.ChannelGroups
  dim chObj : for each chObj in groupObj.channels
    if 0 <> inStr(1, chObj.Name, "ei", vbTextCompare) then
      MsgBox chObj.Name & " " & chObj.ChannelGroup.Properties("index").Value & " " & chObj.Properties("groupindex").Value
    end if
To determine the code to read such properties, you can just drag and drop it from property window into script.
(5,862 Views)
Thank you!!!
(5,845 Views)
