DIAdem
How to import Condalo CCO-DL3 (*.cc3) in DIAdem?
How can I import *cc3 data in DIAdem. I cannot find a data plugin for this case neither does the CAN Konverter work.
(4,083 Views)
Hi Isabell!
It looks like there is no Dataplugin available at the time, so you have two options:
1. Convert the file into a format which can be read by DIAdem natively (e.g. ASC or TXT)
2. Create the Dataplugin yourself: http://zone.ni.com/devzone/cda/epd/p/id/4822
Hope that helps!
(4,054 Views)
I looked into the documentation of the file. From my understanding, the file contains raw data from the CAN bus. Can you please confirm that I understood this correctly ?
If so, the dataplugin would not do the job. We would have to extend the supported formats for the CAN converter.
Andreas
(4,047 Views)
Hm, I guess you are right. I propably skipped over that part when reading the documentation 😉
(4,042 Views)
