DIAdem
How to import Date in TDR text box from data file?
I have a report template that I use frequently for plotting data from files. At the top of the TDR I have a main title text box that says "Daily Operation" usually followed by the date (typed in manually) of that file.
Q: How do I import/reference the date value from the file (pic #1--outlined in black) into the text box (pic #2) I use for the Date? I appreciate any help.
(4,110 Views)
Hey Lab Guy,
What if you try the following in the Text Object?
Daily Operation: @@Data.GetChannel("[1]/Date").Values(1)@@
Let me know if that works for you...
Derrick S.
Product Manager
NI DIAdem
(4,102 Views)
Hi Derrick,
I copied and pasted your command, but I didn't get the result I was looking for (refer to attachment). Perhaps the data plugin I crafted isn't the best, so that may be why I can't extract that value. I'm open to trying something else if you have another idea. As this is more for convenience, I do not wish to take up too much of your time on this-but I do appreciate the help!
(4,037 Views)
Accepted by topic author Lab Guy
Hi Lab Guy,
Looks like you'll need to use the RTT (Real-To-Time) function, which turns the DIAdem date/time real number (fractional seconds since 0 AD) into a date/time string.  There's also a TTR function that goes the other way.
@@RTT(ChD(1, "[1]/Date"), "#mm/dd/yyyy hh:nn:ss.fff")@@
Brad Turpin
DIAdem Product Support Engineer
(4,017 Views)
That code gets the job done--thank you! The previous code will also come in handy, so thanks to you both!! I appreciate the help, gentlemen.
(3,982 Views)
