DIAdem
How to list all signed DataPlugins in a script?
I like to select with a dialog a signed DataPlugin, so I have to list somehow all available DataPlugins...
I just can find the FileFilterExist() function...
Does someone know a function, which will help me?
Thank you very much!
(3,605 Views)
Hi f-zoid,
We don't have a built-in function for you that does this.  I've asked R&D to provide this in the future, as I consider this a very reasonable request.  In the meantime the only workaround I can offer you is to read the information directly out of the same configuration file that DIAdem is reading it out of:
C:\Documents and Settings\All Users\Application Data\National Instruments\Shared\USI\Config\storetypes.usiconfig
But beware.  With Vista these directories may change, and that file used to be called Sources.ini, so this would just be a temporary workaround that would probably break in some future version of DIAdem.
Hope that helps,
Brad Turpin
DIAdem Product Support Engineer
(3,582 Views)
Hi again, f-zoid,
The file path I offered above turns out to be the one for DIAdem 10.1.  The same file in DIAdem 10.0 is at:
C:\Program Files\National Instruments\Shared\USI\Bin\Sources.ini
Brad Turpin
(3,571 Views)
Hey Brad...
Thank you for your help...I will check it...
(3,554 Views)
