DIAdem
How to remove the blank or empty cells in the channel
I have few channels, which are blank or empty(0), is there a way to remove this 0 and shift the data up? PFA
(3,845 Views)
Accepted by topic author Kandukuri_raghavendra
Multiple solutions to your question have been posted on my website at this link:  http://www.savvydiademsolutions.com/view.php?topic=view-panel-manual-data-manipulation
You could also approach the problem by filtering the data, using the View panel Flags (http://www.savvydiademsolutions.com/view.php?topic=view-remove-channel-spikes ), or by using the DIAdem Event Search (http://www.savvydiademsolutions.com/analysis.php?topic=postprocess-event-search-results ).
I hope this helps.  If if does, please mark it as "Solved".
(3,319 Views)
Call DataBlDel(ChnList, ChnRow, ValNo, [ValDelOnly])
http://zone.ni.com/reference/en-XX/help/370858P-01/comoff/databldel/
Call DataBlDel(Channel, 1, 21)
(3,309 Views)
it wont be 21 empty cells every time, it would differ
(3,307 Views)
Dim Channel, zeroCount, i
Set Channel = Data.Root.ChannelGroups([name]).Channels([name])
zeroCount = 0
For i = 1 To Channel.Size Step 1
  If Channel.Values(i) = 0 Then
    zeroCount = zeroCount + 1
  Else
    Exit For
  End If
If zeroCount > 0 Then
  Call DataBlDel(Channel, 1, zeroCount)
End If
(3,303 Views)
