DIAdem
How to see if a curve in VIEW is selected or not using script?
I want to determine (using script) if a curve in VIEW has been selected.  I use this:-
msgbox View.ActiveSheet.ActiveArea.DisplayObj.Curves2D(1).Selected
but the result is FALSE.  I understand 'selected' to mean the curve has been selected by placing a dot as shown here:-
but obviously I am missing something...could someone explain why my line of script does not work as I expected?
Thank you!
(1,787 Views)
Hello mrme,
The curve with the blck dot is the so called Leading Curve.
msgbox View.ActiveSheet.ActiveArea.DisplayObj.Curves2D.LeadingCurve.YChannelName
Greetings
Walter
(1,759 Views)
Hi Walter,
Thanks for the fast response....but I am confused as to what '.Selected' does.
What does Selected' mean ?
What would one use it for?
How do I select a curve in a plot?
kind regards,
Thomas
(1,755 Views)
Accepted by topic author mrme
Hi Thomas,
If you click on left or right grey area in the legend you can select (mark) one or more curves and delete or drag & drop them.
The leading curve marks the curve for the focus of the cursor.
Greetings
Walter
(1,748 Views)
Hi Walter,
Thanks! It is clear now.
Thomas
(1,740 Views)
