DIAdem
How to show 2 frequencies?
I`ve got a problem to show 2 frequencies at DIAdem. I use two hallsensors to get a two speed signals and DIAdem 11.1 with a few moduls (Modul 9401).
How do I build the curcuit diagram in DIAdem DAC? Which devices should I use? Are there templates for this problem?
The next point is, to calculate some signals. How can I calculate, for example "signal1x200" and show it?
Thank you for your help.
greetings
J.Fischer
(3,294 Views)
Hello jafischer
there is a dublicate thread for this issue:
http://forums.ni.com/ni/board/message?board.id=60&message.id=11814
lets keep the discussion single threaded.
Regards
Moritz M.
(3,266 Views)
