DIAdem
Howto efficiently Copy array into data portal
I have an array in VBS memory and would like to create an channel in the data-portal based on that data-set, I currently use this code construct to copy the data:
' intChannelCount is the number of samples
'MaxHold is the data array to be copied
'oFFTMaxHold is the data channel that is the target of the data
for counter = 1 to intChannelCount
      oFFTMaxHold.Values(counter)=MaxHold(counter)
next
 It is rather slow (and if the data preview is open in the data portal) even much slower.
Is there a method to copy the whole array in one operation to a channel?
Ton
My LabVIEW Ideas
(3,734 Views)
Accepted by topic author TCPlomp
Hi Ton,
If you have DIAdem 10.2 or later you can use the following command to do this with one command-- passing the array of values as one of the command's parameters-- this is a common situation when querying records from a data base that you want to load into the Data Portal as channels.
ChanRefsArray = ArrayToChannels(ValuesArray, ChanNamesArray)
In the case of your example below, that would be:
Call ArrayToChannels(MaxHold, Array(oFFTMaxHold.Name))
Brad Turpin
DIAdem Product Support Engineer
(3,723 Views)
