09-02-2009 08:45 AM
I am wondering if it is possible to include a hyperlink inside DIAdem report and then, when exporting to PDF, have this hyperlink in the final PDF document.
I want to have a summary page with hyperlinks to other documents.
Thank you
Egor
09-02-2009 09:05 AM
Hello Egor!
AFAIK is this not possible.
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
09-04-2009 11:13 AM
Hi Egor,
Matthias is correct that there is no feature in DIAdem 11.1 or earlier to support hyperlink export to PDF files. However, if you have a valid URL as text in the REPORT, it will show up as an active link in the PDF file (when viewed by Adobe Acrobat Reader, but not in the Foxit PDF viewer). So if you want the URL to show up with the full URL text as a link, that's all you need to do. If you want a different text to become the URL link, then you need to use 2 texts, with the URL text on top and the descriptive text underneath. If you paint the URL text white, this will look reasonable-- here's an example TDR file and the PDF file it created (courtesy of R&D).
Brad Turpin
DIAdem Product Support Engineer
11-25-2015 10:13 AM - edited 11-25-2015 10:18 AM
I'd like to know if with the new DIADEM 2015 the hyperlink is possible. And, If it is possible to insert a link to another page of the same report?
Fabio
11-26-2015 08:28 AM
Hi Fabio,
No, sadly neither of these features are in DIAdem 2015.
Brad Turpin
