DIAdem
I am using Diadem V10.1. I am trying to Export the pdf report through my script.
I am using Diadem V10.1. I am trying to Export the pdf report through my script. When I try to export individual report manullayFile -> Pdf Export it creates a proper plot in pdf. But I try to get multiple reports from script it, I can see only 1 quarter of the plot as shown in attachment. Can somebody help me how to resolve it.. FYI, I can see Diadem PDF Export Printer enabled in my machine
(5,060 Views)
Hi Sree,
Can you post the VBScript calls you're using to create the partial PDF file?
Brad Turpin
DIAdem Product Support Engineer
(5,012 Views)
''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''Start''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
PrintName = "winspool,DIAdem PDF Export,LPT1:"
PDFResolution = "150 DPI"  '  "2400 DPI" ,  "default"
PDFOptimization = TRUE
PDFFontsEmbedded = FALSE
PDFJPGCompressed = "high"
Call PrintMaxScale("REPORT")
''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''End''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Call PicPrint("WinPrint")
(5,003 Views)
Smiley Very HappyThank you!!!
it was the problem with the unit in the general settings it was 'inch' insted of  'cm',
now i have added a new line to my script and the problem is solved.
If LENGTHUNIT <> "cm" then
  LENGTHUNIT = "cm"
  Call UPDATELENGTHUNIT()
  Call DESKSAVE()
End If
(4,988 Views)
