DIAdem
I'd like to have the average of 2 y-values for 1 x-value
I have acquired data from tests. The data is logged throughout a sweep. This means that for one X value I have got two Y values.
Does anybody know how to get the averages so I got one graph. The data is stored in one channel.
Thanks in advance.
Robert
(3,404 Views)
Hello Robert,
Seems like the reduced loading of data channels could solve your request. If you choose 2 as "Intervall width" and Mean Value as "Reduction mode" you get a new channel with the means for each two values in the input channel. Either interactively from the short cut menue in the browser window of DIAdem NAVIGATOR or in a script using the command DataFileLoadRed.
Hope this helps,
Ralf
(3,391 Views)
Hi Robert,
If your data are arranged such that multiple Y values for the same X value occur right next to each other, then Ralf's suggestion is ideal.  Are they arranged like this?
Y1 for X1
Y2 for X1
Y1 for X2
Y2 for X2
Y1 for Xn
Y2 for Xn
If not, are the X values equidistant (equally spaced: 1, 3, 5, 7...)?
Brad Turpin
DIAdem Product Support Engineer
(3,379 Views)
