DIAdem
Identical setup parameters
I need to setup 2 other PCs with identical DIAdem settings (General properties, etc.). Are there a few files that I can copy to the other PCs that will accomplish this?
George
(3,231 Views)
Hi George,
Pretty much everything is in the "Desktop.DDD" file, which is located in the main DIAdem directory.  Try copying that over to your 2 targets and see if you get all the settings you need.  There are some settings that are stored elsewhere, so if that doesn't take care of everything you need, let us know.
Cheers,
Brad Turpin
DIAdem Product Support Engineer
(3,220 Views)
