DIAdem
Import and use DLL
I have created a DLL in visual studio 2012 , i want to import this DLL to Diadem and using his function.
how can i do that?
(5,943 Views)
Hi OzShimon,
Please have a look at the following example:
Greetings
Walter
(5,939 Views)
Hi, it׳s reqiured LabVIEW Run-Time Engine to be worked...
(5,928 Views)
Hi Oz,
DIAdem always installs the previous year's LabVIEW Runtime Engine.  So DIadem 2012 installed the LabVIEW 2011 Runtime Engine.  You'll need to make sure the LVRTE you need matches the one installed or install a new LVRTE that DIAdem doesn't install.
Brad Turpin
DIAdem Product Support Engineer
(5,921 Views)
Hey,
I did not understand how to import a DLL and use it.
Can you list the steps to import a DLL and use it the script? How to call functions that are in the DLL?
Thank you
(5,913 Views)
Hi Oz,
Here are the options I listed at your other post:
http://forums.ni.com/t5/DIAdem/GPI-help/m-p/2337786/highlight/false#M16521
Brad Turpin
(5,895 Views)
