DIAdem
Import binary Data from LabView
Import binary Data from LabView (specify Optiopns and FileName). The Errocode is allways the same: The file doesn't exists. I have typed in first the complete path and second the filename only. but it don't works. We need an explanation of the properties such like "Initial Position" and "Factor". The Extension of our file is "*.LTD". Did you know the File-Type of this? mailto:luiz.marcatto@voith.com
(3,825 Views)
Luiz,
Would it be possible for you to send me a file and a description of the format (or even the LabVIEW VI) to test this?
Are you aware of the fact that LabVIEW is capable of writing the DIAdem specific binary data format (*.DAT and *.R48)? Maybe that could also be a solution to your problem.
Let me know and I will see what I can do to help,
Otmar
Otmar D. Foehner
(3,824 Views)
