DIAdem
Import template word on report layout
i would create a report with my standard company layout (usually used on word of Office).
how can i import template?
or...
how can i create .tdr layout with different software?
thanks
Manuel
(3,384 Views)
Hi Valbo10,
for the tdr files try to look up this thread: http://forums.ni.com/t5/DIAdem/How-to-set-waveform-axis-range-of-TDR-Report-Layout-file-from/td-p/10....
For the word template you can simply use the Report Generation Toolkit palette and this function:
and wire the path to the template in the "template" input.
Hope this helps,
CorraDIT
(3,351 Views)
