DIAdem
Importing a particular column values from Database into Dialog editor using VBscript
How to import a particular column values from Database into Dialog editor using VBscript
(5,486 Views)
Hi kogila92,
You can use VBScript to query the contents of a full column of values from a data base and programmatically place those values in a new data channel in the Data Portal or in a VBScript variable.  You can also load an entire column of values from a data base column interactively in the NAVIGATOR by dragging it into the Data Portal, which loads a new data channel with that column's values.
Why do you want the values in the SUDialog Editor?
Brad Turpin
DIAdem Product Support Engineer
National Instrumetns
(5,456 Views)
Hi Brad,
Thanks for the support
I need to fetch the values of particular column from database during runtime in the SUDialog editor.
For analysis purpose we need to have the selection option in the UI
Here i have attached the screenshot of how my editor should look..
Can you please suggest me the solution?
(5,444 Views)
