DIAdem
Importing multiple ASCII files into one channel
Hy Brad,
I have a question regarding Diadem, and I didn't find any topic on forum.
I have a device compose by two motors and a controler from Baldor, and I've made a program  with the Baldor soft ( the script is similar like the script used for Diadem -VBS) and I want to use Diadem to start the program from Baldor,and after that to analyze with Diadem the result.
The Poject extension from baldor is .wbx ( see atachment) and he creat a file of data type .csv.
Can I connect Diadem with the program from Baldor? If yes how can I do that?
Why kind of application can I acces with Diadem , but not created with Diadem?
Thank you again for your help.
Message 11 of 12
(1,249 Views)
Hello Marse,
Whether DIAdem can provide the functionality you are looking for depends more on the way Baldor can be controlled. If it is sufficient to simply call the Baldor executable from a DOS shell with DOS commands DIAdem can certainly do that. Also, if Baldor provides support for ActiveX control then DIAdem can control it via ActiveX. Does Baldor provide drivers for additional external applications?
You can find some examples of DIAdem interfacing with different applications in the DIAdem Help. In the Contents tab, expand the Examples tree, then look at the examples in the Using Interfaces tree.
Manooch H.
Message 12 of 12
(1,237 Views)
