DIAdem
Importing special ASCII file
Hi guys,
I have measurement files as ASCII (an example file is attached). It contains 138 lines as header, which I am not interested in, then 3 data channels, x, y, and z, and a timestamp in the form hh:mm:ss dd:mm:yy. This timestamp appears every 41 lines.
Now I want to have a continuous time channel and three x-, y-, z-channels. Using Plugin-assistant I could import the three data channels correctly but time channels not.
Any ideas for how to get around it and generate the right time channel using Plugin-assistant or script?
I am grateful for any help
Milad
(6,310 Views)
Hello Milad,
You can request a free DataPlugin from NI through this link:
DataPlugin request
Please provide the requested information through that link and you'll get a custom DataPlugin for this data format created.
The time channel you have is not really ideal for the ASCII wizard ...
      Otmar
Otmar D. Foehner
(6,293 Views)
Thank you Otmar! Still, I would like to do it myself. Can I find somewhere instructions how to write or edit a plugin?
(5,843 Views)
Hi Milad_A,
Are your data channels aquired at a constant sampling period?  If so, you can have the DataPlugin declare you channels as waveform channels and/or create an implicit date/time channel.  Are there data values in between the datetime values 41 rows apart?
Brad Turpin
DIAdem Product Support Engineer
(5,829 Views)
Hello Milad,
The "manual" (in form of a help file) can be found here: https://www.ni.com/en/support/downloads/dataplugins/dataplugins-programmer-s-reference-guide.html
   Otmar
Otmar D. Foehner
(5,826 Views)
