DIAdem
Importproblems with any biger DDF-Files
Hello
i must be a report import any Bigger DDF-Files( DasyLab)
I have a script to do this, but Diadem Breaks after any files (4-5) with the Answer: Das Laden der Datei"xxx"" mit dem Ladeverfahren "Dasylab" ist Fehlgeschlagen
is this a problem of the Working Memory?
greetings Thomas
(4,703 Views)
Hi Thomas_Gull,
It could be a problem with your available RAM-- how much do you have free on that computer?  What is the largest DasyLab file you can successfully open and the smallest DasyLab that fails to open?  What version of the DasyLab DataPlugin are you using-- I saw today that R&D was about to post a new one.
Brad Turpin
DIAdem Product Support Engineer
(4,664 Views)
it have 4 GB of Work-Memory
i can import 2 files a 400mb
and after the third he breaks with the message.
import 10 files to 100 mb is no problem.
thomas Gull
(4,632 Views)
