DIAdem
In a Table trying to WordWrap a long string
Using a single column and row table to post notes from a data run. The notes may be long and when using a constant font size the string goes off the page, hense the need for WordWrapping
(3,241 Views)
Hello Todd,
I already spoke to you about this issue and sent you a modified TDR, but I thought that I'd answer it for anyone else who might be interested.
You should instead use a "Text Object". It is located in the "Decorations" category in the "Report" view. Double-click on the oject to bring up the "Text Object Editor". Use "DIAdem expression >> new" to be able to access DIAdem channels, variables, and functions. I used the expression "cht(1,13)", for instance, to tell the report to load the text from channel 13 into the Text Oject. The Text Oject automatically wraps around.
Thanks again for contacting National Instruments. Take care!
Aaron B.
(3,241 Views)
