DIAdem
Insert same value to text channels with Diadem function
i got a text channel with 50 rows and i would like to set all values to empty string "". I found function "DataBlInsertVal", but its not for text channels. So i found function "ChnAreaInsert0", this insert zeto value.
Can you please tell me which function i can use. I dont want to iterate through each row and set it, some function to specify start row, number of records AND THE VALUE could be good, im sure there is some, but i cant find it in the sea of fuctions.
Does this function exists?
(2,977 Views)
Accepted by topic author Lukas_Doubek
Hi Lukas,
If you have DIAdem 2015 or later, you can use the Channel.SetValues() command:
Set Group = Data.Root.ChannelGroups(1)
Set Channel = Group.Channels(1)
Call Channel.SetValues("", 1, 50, eValueBlockValueOverwrite)
Brad Turpin
DIAdem Product Support Engineer
(2,945 Views)
Thank you for help Brad .)
(2,939 Views)
