DIAdem
Integration in Analysis vs. ChnIntegrate in Script - Help Brad!!!!
Ok, when I integrate Temp/Power over Temp/RunTime and graph the results in View...everything is as intended.
When I execute this code in a script I get the error following:
Call DataBlCopy("'Time/RunTime','AI\AO Data/Comp_Power'",StartIndex1, _
                 StartIndex2-StartIndex1,"'Temp/RunTime','Temp/Power'", 1)
  ' Now integrate over the range
  Call ChIntegrate("[6]/[1]", "[6]/[2]", "[6]/[3]")
  ' Calculate the max integration result
  CalculatedSUEnergy = CMax(CNo("Temp/Energy"))
Returns this error
PM Error:Type mismatch: 'ChIntegrate'
What am I doing wrong????
(4,046 Views)
Well,  I tried recording the integration action and then cutting and pasting the resulting lines of script.  I get:
                 StartIndex2-StartIndex1,"'Temp/X','Temp/Y'", 1)
  Call ChnIntegrate("Temp/X","Temp/Y","Temp/Integrated") '... XW,Y,E
vs.
Not sure why, but the top one works, the bottom doesn't.  The only difference is the name of channels, which I changed for other reasons.  RunTime & X are [1], Power & Y are [2]
Anyhow, solved!
Message Edited by JeffGrimes on 06-08-2009 11:13 AM
(4,013 Views)
Hi Jeff,
It looks like the issue was the spelling of the function.  The bottom one is missing the "n" in ChnIntegrate.
Mark E.
(4,010 Views)
Thanks, Mark.  Never caught it.
Smiley Sad
(4,007 Views)
