DIAdem
Invalid Specified Worksheet Index
I am getting an error that I cannot solve or work-around. I have simplified the code to the following example:
Call PICLOAD("Report2.tdr")
Call PICFileAppend("Report2.tdr")
call picpdfexport("c:\sample.pdf")
call picdelete
call picexport("c:\sample.wmf", "wmf")
At the PicExport call I get the following error:
"The specified worksheet index (2) is invalid"
Can you please provide a solution or work-around?
I am using Diadem 9.1 SP2.
Thanks.
(3,531 Views)
Hello Cowbreath,
Unfortunaetly you found a bug which is fixed for DIAdem 10.0. As workaround you can set two variables as follows:
call picdelete
PrintFromPage = 1
PrintToPage = 1
Greetings
Walter
(3,519 Views)
Thank you for the work-around.
(3,510 Views)
