DIAdem
Iotech data plugin for DIAdem 2017
Hello...I have previously used Iotech data plugin (for .dsc files) with different versions of DIAdem. Recently, I have DIAdem 2017 and I could not find the data plugin to work with this. Is there a data plugin available to open Iotech (.dsc) files in DIAdem 2017? Thanks.
(3,888 Views)
Hi Rajoria,
Thanks for bringing this up - I've searched through our internal databases, but I was unable to find a download for an IOTech DataPlugin for .dsc files. I did find your older forum post, but the link you referenced previously is no longer valid.
If you still have access to an older download of the IOTech DataPlugin, I would recommend trying to run that previous installer. In the meantime I'm currently reaching out to our DataPlugins teams to see if they have any record of this DataPlugin.
Yiran Li
(3,825 Views)
Thanks. I tried the older dataplugin for .dsc files. But DIAdem 2017 is still not recognizing those files. Thanks for looking into this.
(3,819 Views)
Hi Rajoria,
Good news! One of our IOtech Support engineers was able to find a link for the installer for the IOtech DataPlugin. Please try installing the DataPlugin from here.
If the above link doesn't work, you are welcome to directly contact our IOtech support at IOtech.Support@ni.com.
Best,
Yiran Li
(3,808 Views)
Thanks. I tried the plugin from the link you sent, but it still did not work for DIAdem 2017. I will contact NI's Iotech support. Thanks.
(3,801 Views)
Accepted by topic author rajoria
Looks like IOTech eZ-Analyst being 32-bit application, the plug-in only works for DIAdem 32-bit version and not for 64-bit version.
(3,732 Views)
Hi All,
I asked R&D about this, and they pointed out that there is an approach for loading IoTech data files into a 64bit version of DIAdem.  Please give this a try and let us know if the performance meets your needs.
http://www.ni.com/example/54228/en/
Brad Turpin
DIAdem Product Support Engineer
(3,711 Views)
