DIAdem
Ipetronik timeout
Hi there,
i have a huge problem with the ipetronik driver for diadem. I tryed version 2.26 and version 2.28 both times i get a timeout. With ipconf i can access everything and read data.
Have anybody had the same problems with diadem 10.2, with version 8 i had no problems? I posted the error message as Attachment.
diademi
(5,105 Views)
Hi diademi,
The Ipetronic device driver is developed and maintained by Ipetronic, so if you have questions to the device driver you should ask Ipetronic.
But concerning GPI (API for the device drivers) I remember that we changed the NoValue handling. In the past NoValue was a specific (typically very high) value. We changed it to NaN (Not a Number). Maybe that the driver doesn't support that correct - but this is just a speculation. In the compatibility dialog you can switch to the old behavior.
I hope this can help.
Greetings
Walter
(5,075 Views)
Hi
the latest ipeconf is 2.29. Obviously u use Ipetroník with a Master-Block (e.g. SIM-Master), so the problem is the CAN-Hardware.
I think Ipetronik is not part on your CAN-Hardware (e.g. Vector Can-Card XL). You can sign in Ipetronik in CAN-Hardware using >System-Settings > CAN-Hardware.
KIM/SIM- Baudrate is set by by Ipeconf (666 kB/s).
Hope that will help you.
(5,050 Views)
i checked the vector config already and everything is in place. The weird thing is that sometimes i can fix the error by removing the can-card and plug it in again. Sometime it needs a reboot and rarely it works the first time.
I searched for a pattern but didn´t found one, the config is the same at all time. Any other suggestions?
diademi
(5,039 Views)
wich CanCab do you use. I had such problems using CanCab 251opto. By using the the standard CanCab 251 the problem didn´t appear.
Greetings
(5,031 Views)
It´s a pity. We use 251, that means it is something else.
(5,024 Views)
In that case you should really contact Ipetronik. The german support is really good and they answer very fast.
Greetings
(5,011 Views)
