DIAdem
Is Diadem 9.1 compatible with Windows 7
I have recently upgraded to Windows 7 but cannot get Diadem 9.1 to run. It appears to install fine but when I try to run it it just shows the loading screen and says "Initializing the script engine.." and does not progress any further. Is this a problem because of Windows 7. Are there any updates, drivers, etc that I can install to overcome this?
Many thanks.
(3,563 Views)
Hello DIAdem1234,
DIAdem 9.1 was released in 2004. So it couldn't be tested with Windows 7.
The first DIAdem Version which supports Windows 7 is DIAdem 11.1 SP1
Greetings
Walter
(3,561 Views)
