DIAdem
Is it possible to update dialog variables from a non-modal dialog box?
I would like to have a non-modal dialog box run a script when I hit a "Load" button.  Is this possible?
BG103
(4,462 Views)
Hey BG103,
you can open a non modal SUD Dialog with the following exemplary code snippet:
Dim MyDlg
If Nothing is SudNonModalDlgLst("Dlg1") Then
  Set MyDlg = SudDlgCreate("Dlg1",CurrentScriptPath & "TestDialog.sud")
Else
  Set MyDlg = SudNonModalDlgLst("Dlg1")
End If
Call MyDlg.Show()
In this example I created a TestDialog.sud file with dialog "Dlg1".
In the SUD dialog you can create a button click event which runs ScriptStart function like this:
Sub Button1_EventClick(ByRef This)
  call ScriptStart(CurrentScriptPath & "TestScript.vbs")
End Sub
Regards
Christian
Christian
CLA, CTA, CLED
(4,450 Views)
