DIAdem
Is there a way I can resort the dataportal alphabetically?
So I do a huge list of calculations and creating new channels. I want to be able to resort the list of channels in the group 1 only, alphabetically, at the end of my file. Any ideas on how I could do that?
(5,738 Views)
Accepted by topic author Jcheese
Hi Jcheese,
I happen to have a short script that does that.  Just pass the index of the Group whose Channels you want to sort.
Call ChanSort(1)
Sub ChanSort(GroupIdx)
  Dim i, Swapped, ChNo1, ChNo2
  Do ' Until bubble sort of GroupName() is finished
    Swapped = False
    FOR i = 1 TO GroupChnCount(GroupIdx)-1
      ChNo1 = CNoXGet(GroupIdx, i)
      ChNo2 = CNoXGet(GroupIdx, i+1)
      IF StrComp(UCase(ChnName(ChNo1)), UCase(ChnName(ChNo2))) > 0 THEN
        Call ChnMove(ChNo2, Groupidx, i)
        Swapped = True
      END IF ' Name(i) and Name(i+1) need to be swapped
    NEXT ' i
  Loop Until NOT (Swapped)
End Sub ' ChanSort()
Brad Turpin
DIAdem Product Support Engineer
(5,714 Views)
Thanks - worked perfectly for what I needed.
(5,709 Views)
