DIAdem
Is there a way to change the export default file name
I have a request to change the default file name when doing a pdf export of a report. By deault, when pushing the export to pdf button, the name is NONAME.pdf. They want the default name to be the channel name is displayed on the report.
Is there an easy way to do this, or will I have to load all new code into the export button?
(5,390 Views)
What you'll probably want to do is create a script that uses the Call Report.Sheets.ExportToPDF function and programatically specify the name.  From here, you could set it as one of the function buttons or even include it on the toolbar if you'd like.
Jesse S.
(5,356 Views)
