DIAdem
Is there a way to change the order of graphic colouring in Diadem reports?
Hi. I am working on a waterfall diagram of various FFT curves. The problem is that Diadem draws the curves to the back of the graph last meaning that much of the curves in front are not fully visible. I have tried rotating the graph by 180 degrees but the same problem occurs. Is there a way of avoiding this? I attach an image to explain.Thanks in advance
(3,610 Views)
Hello marcot
Unfortunately there is no image attached and I don’t really understand what you mean with “”…That much of the curves in front are not fully visible.
Here an example for a waterfall diagrams and I would say I can see all plots.
(3,592 Views)
