06-21-2019 08:00 AM
We have report templates with selected channels for auto-processing pdf reports. Unfortunately, DIAdem does not adequately re-scale the pdf report x-axis, resulting in colliding time labels (even with auto-scale selected in plot properties). This results in low confidence that a report won't have formatting errors along the time axis and subsequently someone having to load that data set into DIAdem, go through clicking on each plot and adjusting time scale (extremely time consuming).
Thank you for your time and any suggestions. I can provide screen shots if necessary but it really is just a matter of the x-axis not scaling in a way that will always avoid labels colliding...
BG
Solved! Go to Solution.
06-21-2019 08:39 AM
I use something like this to adjust my reports before I export them. You should be able to add something like this to script that loads the data into DIAdem. This is an easy way to make sure that the formatting and spacing is consistent across your PDF, but also can be used to make quick modifications to any REPORT templates which have a lot of tabs.
Sub FormatGraphs
  Dim i
  For i = 1 to Report.Sheets.Count
    Set oSheet = Report.Sheets(i)
    If oSheet.Objects.Exists("2DAxis1") Then Set oGraph = Report.ActiveSheet.Objects("2DAxis1")
    oGraph.XAxis.Label.Text               = saNC_XAxis_Label(i)
    oGraph.XAxis.Scaling.AutoScalingType  = paNC_XAxis_Scaling(j)
    oGraph.XAxis.Scaling.Begin            = iaNC_XAxis_Start(j)
    oGraph.XAxis.Scaling.Tick.Distance    = iaNC_XAxis_Tick(j)
    oGraph.YAxis.Label.Text               = saNC_YAxis_Label(i)
    oGraph.YAxis.Scaling.AutoScalingType  = paNC_YAxis_Scaling(j)
    oGraph.YAxis.Scaling.Begin            = iaNC_YAxis_Start(j)
    oGraph.YAxis.Scaling.Tick.Distance    = iaNC_YAxis_Tick(j)
    oGraph.CurveLegend.Position.RelativePosition      = paNC_Legend_RelPos(j)
    oGraph.CurveLegend.Position.Anchor.SystemRelatedX = iaNC_Legend_XAnchor(j)
    oGraph.CurveLegend.Position.Anchor.SystemRelatedY = iaNC_Legend_YAnchor(j)
  Next 'i
End Sub
		06-21-2019 11:05 AM
Amazing. Time unspoken has been lost to manually updating these things. Thanks!
