DIAdem
Is there any changes in the DIAdem script between DIAdem 9.x and DIAdem 10.x ?
I have got a question about DIAdem Script.
I saw the compatibility problem described in KB.
'Why do my DIAdem 9.1 Scripts not work in DIAdem 10?'
Many problems were solved, but some case were not.
So I guess there is some changes in the DIAdem script between DIAdem 9.x and DIAdem 10.x
Thanks for your help.
(3,364 Views)
Hi supportko...
Yes, there were a lot of new features introduced in DIAdem 10.0, and 10.1.  These are described in detail in each product's ReadMe file, and also in the Online Help under  the "Index" tab at the node "DIAdem>>New Features>>New Commands and Variables"-- you will see 2 sections there:  "Version 10.1", and "Version 10.0", showing you exactly what has changed.  In most cases there is a compatability switch whenever a new feature creates a compatability issue for scripts developed in a previous DIAdem version.  R&D works very hard to minimize the impact of new features on existing VBScript applications.
Brad Turpin
DIAdem Product Support Engineer
Message Edited by Support on 05-02-2007 03:56 PM
(3,337 Views)
