DIAdem
Kurtosis and Skewness
Is there a way to calculate Kurtosis and Skewness value for each each second of data that is a long set of 360secs? Basically speaking, I need 360 values of kurtosis and skewness.
(3,122 Views)
Set Group = Data.Root.ChannelGroups(1)
Set DatChannel = Group.Channels(1)
Set KurtosisChannel = Group.Channels.Add("Kurtosis", DataTypeChnFloat64)
Set SkewnessChannel = Group.Channels.Add("Skewness", DataTypeChnFloat64)
FOR n = 1 TO 23
  StatSel(n) = "No"
NEXT ' n
StatSel(22)  = "Yes" ' Kurtosis
StatSel(21)  = "Yes" ' Skewness
StatResChn = FALSE
StatClipCopy = FALSE
StatClipValue = FALSE
iMax  = DatChannel.Size
Start = DatChannel.Properties("wf_start_offset").Value
Delta = DatChannel.Properties("wf_increment").Value
Call ChnWfPropSet(KurtosisChannel, "Time", "s", (Start+1)/2, 1)
Call ChnWfPropSet(SkewnessChannel, "Time", "s", (Start+1)/2, 1)
SecVals = 1/Delta
FOR i = 1 TO iMax Step SecVals
  k = k + 1
  P1 = i
  P2 = CStr(i+SecVals-1)
  IF P2 > iMax THEN P2 = iMax
  RowRange = P1 & "-" & P2
  Call StatBlockCalc("Channel", RowRange, DatChannel)
  KurtosisChannel(k) = StatKurtosis
  SkewnessChannel(k) = StatSkew
NEXT ' Until end of channel
I am using the above script to find values. I am getting all the values I need. Here is the thing, the skewness values are negative and kurtosis are positive.
But when I run statistical values on the whole data, my skewnedd value is positive and kurtosis is negative.
Is that correct or is something wrong in my script?
(3,115 Views)
Hey hmurya,
Thanks for posting. On first glance that would be how I would expect to calculate the kurtosis and skewness according to our documentation.
Command: StatBlockCalc - http://zone.ni.com/reference/en-XX/help/370859J-01/comoff/statblockcalc/
Maybe it might be good to try a clean known data set and see if we still see the same results. I think our Kurtosis should be 3 if we're testing a normal distribution and it should be 1 if we're testing a discrete distribution (discrete: equally likely values). From there we could also do a quick check on the skewness since it has a relation to the Kurtosis.
Hopefully that gives us a good starting place to figure out our script is doing what we want.
JY
Application Engineer, RF and Communications
(3,073 Views)
