DIAdem
.LVM file not importing to Diadem
I am trying to import a .LVM file into DIAdem and I get the following message when running the script file I've written.
"Cannot load file log02.lvm with loading process LVM"
Error message for loading process:
Invalid format of file "log02.lvm"
"Error no.: 11"
Yet when I save it to an Excel file format, it imports just fine. If I try to manually import the data from the log02.lvm file, it just locks up DIAdem and doesn't respond. I have included the script file and the log02.lvm file with this email as well as the converted .lvm file to excel file.
(3,482 Views)
The problem is located in the LVM file. In line 13 is the number of channels defined in this case it is 13. In fact the file contains 74 channels. So if you change the number from 13 to 74 you can load the values.
I hope this will help you.
Greetings
Walter Rick
(3,481 Views)
