DIAdem
LabVIEW DataFinder Toolkit: Query options not the same as in DIAdem?
I've been setting up a DataFinder Server to index a bunch of TDMS and MDF files and have gotten it to play nicely with DIAdem.
As a LabVIEW-guy, I've quickly moved on to playing with the LabVIEW DataFinder Toolkit, to see what I can do with it.
I've noticed that within DIAdem, it is much faster to get advanced search results using the setting "Search Results as PreDefined Data Columns" rather than the "Search Results as Elements"... especially when expecting a long list of results.
However, it seems like you don't have that option in the LabVIEW toolkit?  Why not?  Seems like a simple enough option to add.
(2,738 Views)
Additional note / question...  Is there a LabVIEW DataFinder Toolkit install for 64-bit versions of LabVIEW?
If DataFinder Server is 64-bit, and uses 64-bit USI DataPlugins, but you can only use a 32-bit LabVIEW DataFinder Toolkit, won't there be problems with plugin bit-ness?  See post:  DataPlugin for DataFinder Server using LabVIEW SDK - 32-bit, 64-bit, OH MY!
(2,707 Views)
