DIAdem
Label is getting invisible in 2D plot when 2 or more channels are dropped in to VIEW
Hi
I am trying to plot two channels on the same graph.When I am dropping the first channel y axis is displaying the unit but when I drop the second it disappears.When I transfer to report also it is not coming.Do any body experienced this problem.how to solve it
Certified LabVIEW Developer
(4,459 Views)
Hello mjaugustin,
This is expected behavior if you only have one Y-Axis in VIEW.
Have you tried selecting "n Y-Axes" in the settings for the graph? That gives you the result you would expect. With only one Y-axis, we cannot determine what unit you would prefer to see on the axis ...
Let me know if that helps,
      Otmar
Otmar D. Foehner
(4,440 Views)
Thanks a lot for you reply.
I also tried this .But after transferring to report I am able to do this ie. by labelling
Thanks once again
(4,437 Views)
